About Add an Alert
Hello Adam,
I met a trouble when i tried to create an alert on a property. I found the service "AddOrUpdateAlert" and wrote an example in below.
// test example var table = attributes.alertAttributes; var params = { alertType: "Above" /* STRING */, alertName: "h_above" /* STRING /, property: "humidity" / STRING /, description: "humidity above threshold value" / STRING /, attributes: ???? / INFOTABLE /, priority: 1 / INTEGER /, persistent: true / BOOLEAN /, enabled: true / BOOLEAN */ }; me.AddOrUpdateAlert(params);
But there is a parameter that called "attributes" and type is INFOTABLE. I want to know what is mean about this parameter. Can you give me some advice/hint about how to create/modify an alert ? Thank you so much for your always support.
