Accesing Windchill folder contents
Hi everyone,
We're attempting to create a simple applet in Thingworx that accesses our windchill repo. So far we've been able to create queries that can fetch our available container and folder types. However, we are unable to access the objects (ei. parts, process plans, documents) contained within the folders by using a conventional query.
The Windchill extension query service takes:
var params = {
containerUfid:   /* STRING    OR:wt.pdmlink.PDMLinkProduct:2559991*/,
criteria:  /* STRING */,
type:  /* STRING */,
dataShape: /* DATASHAPENAME */
After using our subfolder obid in our queries, we got the following error:
Wrapped com.ptc.jws.service.com.ptc.windchill.ws.Exception_Exception: com.infoengine.util.IEException: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer Nested exception is: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer; nested exception is: wt.util.WTException: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer Nested exception is: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer Cause: com.infoengine.util.IEException: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer Nested exception is: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer; nested exception is: wt.util.WTException: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer Nested exception is: java.lang.ClassCastException: wt.folder.SubFolder cannot be cast to wt.inf.container.WTContainer
Note: We've been using the container and folder "obid" properties to navigate and query folders.
Kevin Fuerte Could you please post this query on Windchill Questions - PTC User Community so that Navigate/Windchill customization team can review and provide details.
Mohit Goel​
I tried to recreate the issue. The input parameter 'containerUfid' does not seem to take subfolder ufids. It takes only the product container oid. So a solution i can think is that make a query on the Container OID which will return all the subfolder objects. The write a query on the 'folderingInfo--parentFolder' column of the result infotable for the corresponding subfolder id. The second query will provide you the filtered list of objects within the particular subfolders.
Thanks and regards,
SaranKarthick
