Active status button
  • February 17, 2015
  • 3 replies
  • 1275 views
I need to have Indication of last selected button in a Pop-up.Indication could be any changed color of button or highlighting that particular button.
Scenerio: I have a Time Selection Pop-up with 10 buttons,each button for different hours.e.g. button 1 "last 2 hours",button 2 "Last 24 hours" and so on.When I select button 1,pop-up will close and data for last 2 hours will be generated on dashboards.Now again,I open Pop-up to select another button but this time,previously selected button i.e. "last 2 hours" should be indicated as last selection,either by change in color or highlights on button itself.
    For this type of selection you should use the Radio Button widget.  This allows you to define a list of available buttons and lets you bind selected text or selected value to the widget to accomplish what you need.
    Right now I have Navigation buttons to be clicked,Is it possible to replace Navigation buttons with Radio buttons?
