you can found the Thing "SystemRepository" (you need to set checkbox Show System Objects on Filters).
Use the Service "getFileListing()" and take the Column path.
You can get the Content with the Service "LoadImage()" on the same Thing by passing the path as parameter.
Best regards
Marc
