Aug 22, 2024 10:02 AM UTC
add json data to infotable
Hi! i have read alot of documentation but cant find how to do this in TW9.5 i get succes on everything but it just adds empty lines in my infotable. i have added the json and service below
{"station":"station_3","Artikelnr":2053,"antal":46,"vo":767,"Embalage":"Packaging_3","operator":"Operator_4","Antalskort":3}
var dataTableName = "Proddata";
var dataShapeName = ".datashape.lucas";
var result = "Success";
try {
 var dataToAdd = dataToAdd;
 var jsonData = JSON.parse(dataToAdd);
 logger.debug("Incoming JSON data: " + jsonData);
 // Directly access the InfoTable property on the Thing
 var infoTable = me[dataTableName];
 // Directly create a ValueCollection from the JSON data
 var rowValues = new Object();
 rowValues.station = jsonData.station;
 rowValues.Artikelnr = jsonData.Artikelnr;
 rowValues.antal = jsonData.antal;
 rowValues.vo = jsonData.vo;
 rowValues.Embalage = jsonData.Embalage;
 rowValues.operator = jsonData.operator;
 rowValues.Antalskort = jsonData.Antalskort;
 logger.debug("Row values created: " + JSON.stringify(rowValues));
//	var stringifyRowValues = JSON.stringify(rowValues);
 logger.debug('RowValues to use' + (rowValues) );
 // Add the row to the existing InfoTable
 infoTable.AddRow({
 row: rowValues
 logger.info("Data added to InfoTable successfully!");
} catch (err) {
 logger.error("Error processing data: " + err.message);
 result = "Error: " + err.message;
result;
Arun_CAnswer
Aug 23, 2024 5:29 AM UTC
Hi @LL_10926685 ,
Kindly find this below code it may helps you. If any queries kindly do let me know.
try {
 // Assuming dataToAdd is coming from somewhere within the code or an input
 logger.debug("Incoming JSON data: " + JSON.stringify(jsonData));
 // Create a new row object to match the expected structure of the InfoTable
 var rowValues = {
 station: jsonData.station,
 Artikelnr: jsonData.Artikelnr,
 antal: jsonData.antal,
 vo: jsonData.vo,
 Embalage: jsonData.Embalage,
 operator: jsonData.operator,
 Antalskort: jsonData.Antalskort
 infoTable.AddRow(rowValues);
} catch (err) {
result;
Thanks & Regards,
Arun C
Arun_C16-PearlAnswer
Hi @LL_10926685 ,
try {
 var rowValues = {
 vo: jsonData.vo,
} catch (err) {
result;
Thanks & Regards,
Arun C
