Jan 30, 2014 10:10 PM UTC
Add limit lines to a Time Series Chart
What is the best way to add limit lines to a Time Series Chart?  I have a property of my Thing that is an upper limit and I would like to display that on a Time Series chart along with the time varying data.
Loren
Jan 31, 2014 12:44 AM UTC
Hi Loren,
The easiest (and only) way to add limit lines to a Time Series Chart is to add an additional column to your data containing the limit value for each record. Depending on your current implementation, you may need to create a wrapper Service that adds the additional column or modify your existing Service. In both cases, you'll want to use
DeriveFields()
to add the additional column. The code snippet for
DeriveFields()
is available from the Snippets tab.
DeriveFields()
 takes an expression parameter, which you can use to perform a calculation or simply pass in a numeric constant.
Adam
Nov 11, 2015 1:46 PM UTC
Hi Adam,
DeriveFields()​​'s expression parameter accept only a constant value, or a calculation based on existing fields of data. How can I use a variable in expression parameter, for example, a limit given by user ? I tried to give the name of the variable, and I get the error "Script evaluation error : ReferenceError: "myLimit" is not defined."
Quang-Dung
Nov 11, 2015 1:51 PM UTC
Derive fields can take 'any expression' like .5*[FieldName] to create a value based on a column of the table.
or even Things[MyCalculator].LimitCalc({Parameter:[FieldName]}) to invoke a service.
Apr 19, 2017 11:17 AM UTC
Can someone actually help me to use a property to put an upper limit on time series? Please guide me on how to use DeriveFields to use a parameter and how to further use it?
Apr 19, 2017 12:11 PM UTC
If your Thing is "MyThing" and the property "UpperLimit" is the limit for the Time Series Chart, you can use the code below to add the column limit to your data before return to the chart:
var data = ...;
var params = {
  types: "NUMBER" /* STRING */,
  t: data /* INFOTABLE */,
  columns: "limit" /* STRING */,
  expressions: 'Things["MyThing"].UpperLimit' /* STRING */
var result = Resources["InfoTableFunctions"].DeriveFields(params);
