Add multiple points on same x-axis coordinate
Can you add multiple points on the same x-axis coordinate (different y-axis coordinates) of a label chart?
(So the points are oriented vertically underneath each other)
If yes, how? I also have other series on the chart.
Thanks in advance
Hi @TS_9588135
Would you have a screenshot of the end result you want to get , I am not sure to understand what you mean ?
Christophe
