Add row in DataTable
Hi All,
I am creating a service that add row into a DataTable.
The problem is..I dont know my fields name.
So what I need is to iterate through  the fields and add the values I want.
Something like...
for(each field){
myDataTable.field.value = value[x];
x++;
But in "Thingworx language".
Any tips?
Thanks!
22-Sapphire I
I think this could help, you should be able to iterate through the Fields I think and get the names of the Fields.
http://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=IteratingThroughaThingsProperties&action=show
Iterating Through a Thing's Properties
You can easily iterate through a Thing's properties and examine the properties using the following technique:
// GetPropertyValues(): returns an INFOTABLE
var values = me.GetPropertyValues();var field;
// Now we can iterate through the INFOTABLE FIELDS through the DataShape
for each(field in values.dataShape.fields) {
var propValue = values[field.name];
if(field.baseType == "NUMBER") logger.warn(field.name + " " + field.baseType + " " + propValue);
You can even access the aspects of an individual field. For example, when you create a property, there are additional aspects of the property that you can define. Use the following technique/pattern to examine the property's aspects:
  • field.aspects(isPersistent)
  • field.aspects(minimumValue)
The function getProperty returns only generic fields of my datatable, but nothing about datashape.
var values = me.CreateValues();
values.a= undefined; //STRING
values.b= undefined;
What I want is: get my datashape fields and insert values...without using the code above but iterating.
22-Sapphire I
If you know which Property is your InfoTable then you can just iterate to get the fields.
for each (var field in infotable.fields)
I have some actual example lying around somewhere I could dig up, but this should work.
