Adding a ThingShape to a ThingTemplate which is non-editable
Hi All,
I have a query related to adding a thing shape dynamically onto a thing template but the issue is that the thing template, as well as the shape, is part of an extension, which means they are non-editable. By attaching the shape to the template a new functionality will be achieved by the things created under that template.
Please let me know if there is a way to attach a shape to a template dynamically (non-editable template)
Thanks in Advance!
slangleyAnswer
Support
Hi @SrijithKrish
You could create 2 templates.  One would be just the base template without the shape, and the 2nd one would be a new template that implements the 1st template and the shape.  You could actually eliminate the shape and just use 1 template to implement the 2nd template and make all entities non-editable.  These scenarios would prevent the need to dynamically attach the shape.
--Sharon
@SrijithKrish :You can try packaging entities as editable in your custom extension so that templates and shapes can be edited. Please check following article:
https://www.ptc.com/en/support/article/CS323766
@abjain actually I do not require the entities to be editable. The entities should be non-editable themselves because no user should be able to edit within these entities.
If I was to make the entities editable I will have to do it manually for all the entities separately and I am having more than 100 templates.
@abjain so here is it mentioning making an entity editable after importing as an extension. If that is the case will I be able to change the entity to editable and attach the shape and then turn it back to non-editable?
Support
Hi @SrijithKrish
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
