adding widget in responsive layout/container without making Static positioning
I have to add a widget in Responsive layout at Both side (left and right of responsive layout) .
how we can add ?
thanks
@Ashritha
Thanks for the reply , Just i got it by adding container for each widget in responsive area.
Hi @VS_9760165 ,
You can make use of sidebars of layout. Size of the sidebars can be fixed.
Or add extra 2 columns to the layout and vary the width (% ) as required.
Hope it Helps!!
Hi @Ashritha
I am using ThingWorx 8.5.10-b597 and here i can't see any sidebar option, and if we make width as fixed then i cant see it responsive at any screen size. what is solution? i want only one container (responsive) and in that have to position the widget anywhere. how we can...
Hi  @VS_9760165
Please share the snapshot of your requirement.
