Adjust the tree widget width at runtime
I want to adjust the tree widget width at runtime same as drag the width of the tree.
How to achieve?. Could you suggest how to implement .
Thank you in advance..
20-Turquoise
The tree widget is not supported. Please look into using the grid advanced extension which contains a tree grid.
Alternatively, you may try looking into a) custom CSS b) customizing or developing your own widget extension.
Support
Hi @vi1.
If the response provided by @posipova answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
