Jul 5, 2021 10:22 AM UTC
Administrators
Need to check whether logged in user is in Administrators group or not using Thingworx service.
As I checked there is no specific service related to this or list of users in Administrators group can also help.
Please let me know if I can get this Info using any inbuilt thingworx services.
yhanAnswer
Jul 5, 2021 10:46 AM UTC
You can use below custom service to get the list of specific Group Members:
Input: UserGroup //string--"A valid UserGroup name",like Administrators
Output: Group_Member //InfoTable with fiels name, description and type
//Declare our recursion depth cap to ensure that the loop will exit at some point incase an error in ThingWorx allows
//for a circular group reference
var recursionLevel = 0;
var recursionLevelCap = 20;
//Determine if the UserGroup variable is actually a user group
if(!Groups[UserGroup])
 logger.error("Service call " + me.name + "::GetAllUsersInGroup() was supplied invalid UserGroup name, service commencing exit.");
else //If our UserGroup input is valid, continue with service
 //Recursive function call
 var groupMembers = buildMemberInfotable(0, UserGroup);
 // Return all group members after removing duplicates and sorting by name
 //Build params to remove duplicate entries
 var params = {
 t: groupMembers /* INFOTABLE */,
 columns: "name,description,type" /* STRING */
 //Remove duplicate entries
 var result = Resources["InfoTableFunctions"].Distinct(params);
 //Build sort params
 var params = {
 sortColumn: "name" /* STRING */,
 t: result /* INFOTABLE */,
 ascending: true /* BOOLEAN */
 //Sort by user name
 var result = Resources["InfoTableFunctions"].Sort(params);
//Recursive function to find all group members in a User Group structure
function buildMemberInfotable( recursionLevel, UserGroup )
 var params = {
 infoTableName : "InfoTable",
 dataShapeName : "GroupMember"
 // CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(GroupMember)
 var finalMemberReturnTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
 //Only proceed if we haven't hit the recursion depth level cap
 if(recursionLevel < recursionLevelCap)
 //Increment the recursionLevel for the next pass
 recursionLevel++;
 // result: INFOTABLE dataShape: GroupMember
 var groupAndMemberInfotable = Groups[UserGroup].GetGroupMembers();
 var tableLength = groupAndMemberInfotable.rows.length;
 //Loop through the members found, if they are a user, add them to the return table
 //If not, use recursion and go deeper
 for(var x = 0; x < tableLength; x++)
 var row = groupAndMemberInfotable.rows[x];
 if(row.type == "User")
 finalMemberReturnTable.AddRow(row);
 else
 var recursiveTable = buildMemberInfotable( recursionLevel, row.name );
 var params = {
 t1: recursiveTable /* INFOTABLE */,
 t2: finalMemberReturnTable /* INFOTABLE */
 finalMemberReturnTable = Resources["InfoTableFunctions"].Union(params);
 //Return the members found at this level and deeper
 return finalMemberReturnTable;
First of all, you have to get the logged-in user name, to do this you can use SecurityMonitor Thing which has a built-in event "LoginSucceeded". You can use this event to get the username of the logged-in user. Once you get the user name, you can use the below service to check if that user is a part of the administrator.
let result = Groups["Administrators"].GetGroupMember({
name: "pass the name of the logged in user" /* STRING */
If this user is a part of the Administrator, this service will return 1 row for that user, if not this will throw an error.
yhan17-PeridotAnswer
 var params = {
 //Build sort params
 var params = {
 //Sort by user name
 var params = {
 recursionLevel++;
 else
 var params = {
