Feb 27, 2026 3:44 PM UTC
Advance Tree widget
Hello Everyone,
We are using the Advanced Tree widget in our mashup. The same widget works fine in the QA environment but fails in the PROD environment. Could this be related to data loading?
In PROD, both the search functionality and the parent-child relationship are failing. Both environments are running on ThingWorx 9.1.
Thank you
Mar 3, 2026 12:41 AM UTC
Hi @MM_9023322  Could you compare the extension in both environments?
