Advanced grid column edit
    I am looking for functionality like to edit the column in the advanced grid. I have written the JSON string which assigned to the configuration column. But still, I am not able to get that. Is there any example code to achieve this.
Please advice
Thanks in Advance
Vamsi N
20-Turquoise
Could you please clarify your use  case? You should be able to edit values in Grid Advanced out of the box, as well as provide service-driven configuration.
