Sep 12, 2019 12:08 PM UTC
Advanced Grid - Unable to Delete A Row
I have a mashup parameter object that contains a few infotables. My advanced grid widget has its data bound to one of those infotables. I am able to edit and add rows on the front end, but unable to delete rows on the frontend. Has anyone experienced this issue before, and/or do you have any ideas on how I can solve this problem?
raluca_edu
Sep 12, 2019 12:13 PM UTC
You can do that through DeletedTable (similar with EditedTable).
Best regards,
Raluca Edu
berkob1-VisitorAuthor
Sep 12, 2019 12:23 PM UTC
Thanks Raluca,
However, I think you may have misunderstood my issue. When I click "edit" then select a row and click "delete" the DeletedTable is not being populated
Oct 13, 2019 9:09 AM UTC
Berkob,
I have the same issue, did you ever find a resolution?
Dec 27, 2019 1:08 PM UTC
I have exactly the same issue when using advance grid. Has this already been reported?
