May 6, 2025 12:54 PM UTC
After enabling private end point connection on Azure SQL service,Thingworx server is not running
After enabling private end point connection on Azure SQL service, Thingworx server is not running. Is there any other configuration do we need to do on Thingworx side. I have updated private end point link for database in Platform settings file.
Below is configuration in Platform-Settings.json file for Azure SQL .
"PersistenceProviderPackageConfigs": {
"AzuresqlPersistenceProviderPackage": {
"ConnectionInformation": {
    "driverClass": "com.microsoft.sqlserver.jdbc.SQLServerDriver",
"jdbcUrl": "jdbc:sqlserver://xxxxx.privatelink.database.windows.net:1433;databaseName=thingworx;applicationName=Thingworx;encrypt=true;trustServerCertificate=true",
"password": "x",xxxxxx
"username": "twadmin"
Thanks&Regards,
Latha
May 7, 2025 2:13 PM UTC
Hello @vi1
I am not sure about your Thingworx version but you can refer following guide which can help you with the configuration for azure sql
https://support.ptc.com/help/thingworx/platform/r9.7/en/index.html#page/ThingWorx/Help/Installation/Installation/install_java_and_apache_tomcat__ubuntu_.html
Please feel free to revert in case it doesn't help or you have any further queries.
Support
May 8, 2025 7:40 AM UTC
Hi @vi1,
What error message is logged in the ApplicationLog?
Additionally, could you confirm if the jdbcUrl is correct and accessible from the ThingWorx server network?
