Alignment of mashup is not working as expected while using POPup in thingworx
Hello
I have a responsive mashup and i am using navigate function to open mashup in a popup window .
But the alignment is never set to the way i want to use it always behave differently
Any help will be appreciated
Hello @unknown ,
As I can check, this is NOT possible in ThingWorx 9.3 version. You may refer the below linked article for your reference:
https://www.ptc.com/en/support/article/CS416898
Bhawna
Hello @unknown ,
could you pls provide the following info for better understanding:
1. Version of ThingWorx
2.Are you customizing the Popup window or Mashup window?
Bhawna
@unknown  Also Share the sample entities (if feasible).
