All Drop downs showing same value.
I have 3 drop downs bind to the same service whose output is list of mashups in the project.
When i try to change the value of drop down 1 then the value in the other 2 drop downs automatically change to the same value.
I need all the 3 drop downs to show values that user has selected.
I don't understand how the 3 mashups are connected.
Also is there a good way to default the previously selected values when the mashup is loaded.
You have to use 3 different services to bind with 3 drop down buttons.
Kindly find the attachment.
Is there no way I can use the same service to populate the data. All the three drop downs should populate the same list.
You can call the same service three times,
