nmutterAnswer
Sep 1, 2026 10:29 AM UTC
I wrote a script which fetches the log records via POST request
https://" + env.getHost() + "/Thingworx/Logs/" + logType + "/Services/QueryLogEntries
e.g.
ApplicationLog,ScriptLog,
body
{\n" + "  \"startDate\": \"" + startDate + "\",\n" + "  \"endDate\": \"" + endDate + "\",\n"      + "  \"maxItems\": 1000000,\n" + "  \"fromLogLevel\": \"ALL\",\n" + "  \"instance\": \"\",\n"      + "  \"origin\": \"\",\n" + "  \"searchExpression\": \".*.*\",\n" + "  \"thread\": \"\",\n"      + "  \"toLogLevel\": \"ALL\",\n" + "  \"user\": \"\",\n" + "  \"isRegex\": true,\n"      + "  \"oldestFirst\": false\n" + "}
and saves them into a file. like what Composer Monitoring uses to fetch logs. It’s not ideal - but works :D
If you have access to the ThingworxStorage directly you could get the logs via file system. But I only have Composer access and need to download them like that..
nmutter17-PeridotAnswer
e.g.
body
