Analytics Manager > Analysis Models csv upload
I am using Analysis Manager > Analysis Models to create a model from PMML file and upload csv data for testing.
I was successful in creating the the model(Analysis provider Connector : TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector). Selected the Test in model details, used upload input files option to upload the csv file consisting of data, with column names same as shown in Input Data Shape  field.
But the data rows are not loading.
Also, I didn't now find any detail documents regarding this process, would be helpful if share one.
Hi @SriH
The File Upload can only be used for model that accept a fileURL as input (in addition to independent variables)
This is usually never the case.
In almost every situation you can use the Test UI by entering the row manually in the UI.
See also https://www.ptc.com/en/support/article/cs356471
Kind regards
Christophe
