Analytics Tutorial from scratch
I am looking for on Analytics which I can start things from scratch on my Thingworkx installation.
The guides which are available  are based on the Trail Edition,  For example "Operationalize an Analytics Model" does not work on full fledged version of Thingworx because  - ThingPredictor is installed and configured to point to Analytics Manager automatically as part of the installation of the Analytics Trial Edition (ATE).
The guide does not explain how to install and configure ThingPredictor
I would like to start doing a tutorial from scratch so that I get the full end to end concepts clear. Can anyone of you help me with this ?
Regards
Girish
jgreinerAnswer
Hi Girish,
You can install ThingPredictor anywhere you like, as long as it can communicate with ThingWorx Composer.
Let me know if you have any further questions or concerns.
Warm Regards,
John
Hi Girish,
Did yo view this: https://www.ptc.com/en/support/article?n=CS262212
Best,
Asia
gkumar-211-VisitorAuthor
THank Asia,
I had gone through the two videos
In the first video
Creating Analysis Provider and start ThingPredictor Agent via Analytics Manage
1. There is yml file opened for inspection to check all the parameters are correct or not where is this getting created ? for me the thingworx and analytics server are not locally installed (they both are in EC2) I access thingworx from my laptop. This is perfect cloud kind of deployment I am trying out. So not sure in which machine this yml file will be created.
2. You  had explain about down loading a jar file,  (Agent) where do you down load this. -Can you explain ?
I am relatively new  to Thingworx Analytics, that is why I am asking this question. I am looking for something really basic. Where I can get the concepts clear by setting up a demo of my own.
Regards
Girish
Hi Girish,
ThingPredictor is an offering from ThingWorx Analytics but is a standalone product from the Analytics Server so it requires its own download and installation.  You can download ThingPredictor from the PTC support site under the Product Family ThingWorx Analytics.  Make sure that the version of ThingPredictor you download matches the versions of ThingWorx Composer you are using.
The ThingPredictor Download will contain the yml and jar files that were used in the video demos.
Let me know if you have any other questions or concerns.
Warm Regards,
John
