AnalyticsGateway's properties - isConnected always shows false
你好
我安装ATE的那天,我可以正常使用它,但它在第二天不能工作。
到期日期已更改。
这是命令“docker ps”和  “docker ps -a”的结果
1533285906(1)
谢谢
CCi_9
nsampatAnswer
That may be causing improper shutdown of the containers.
Its highly recommended that you use the Analytics Shutdown utility prior to turning off your system.
It has been known to cause problems with the application in what we call violent shutdowns, which can corrupt containers or our microservices in the native installation.
- Neel
Thank you for posting your question to the PTC Community.
Unfortunately, I am only able to provide assistance in English. Are you able to provide what the issue you are facing is in English?
Neel
CCi_91-VisitorAuthor
Sorry, I made a mistake
On the day I installed ATE, I could use it normally, but it could not work on the second day.
The expiration date has been changed.
here is the result of command"docker ps" and "docker ps -a"
1533285906(1)
CCi_9
Can you provide me a screenshot of any errors in Application Log and the Script Log?
ALso, have you reviewed this article, checking if the config connections IPs still match?
https://www.ptc.com/en/support/article?n=CS273969
Neel
