Android App Issue when connecting to TW Server
I'm trying to create an Android App using the Java SDK and i am encountering a connection issue when starting up the app.
09-29 14:15:32.896 12257-12275/com.ptc.ptcnet.sensoren I/System.out﹕ 14:15:32.895 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
09-29 14:15:32.896 12257-12275/com.ptc.ptcnet.sensoren I/System.out﹕ 14:15:32.896 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: SeamSensorGateway, id: 0]. Attempting [re]connect...
09-29 14:15:32.896 12257-12275/com.ptc.ptcnet.sensoren I/System.out﹕ 14:15:32.896 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
09-29 14:15:32.897 12257-12275/com.ptc.ptcnet.sensoren I/System.out﹕ 14:15:32.897 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
09-29 14:15:32.897 12257-12275/com.ptc.ptcnet.sensoren I/System.out﹕ 14:15:32.897 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://10.199.66.97:8080/Thingworx/WS] failed : Attempt to invoke interface method 'io.netty.channel.Channel io.netty.channel.ChannelFuture.channel()' on a null object reference
09-29 14:15:32.898 12257-12275/com.ptc.ptcnet.sensoren I/System.out﹕ 14:15:32.898 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: SeamSensorGateway, id: 0]
Can anybody help me with this?
Kind regards Philip
