any other widget available to replace slider widget
In slider widget, accuracy in selecting  value is low. Any other widget available to select range or any extension available ?
AshrithaAnswer
We can achieve higher accurate value using slider widget
This can be achieved by step size = 0.01   and precision = 2
If more precision required  increase step size like 0.001  and precision =3 so on.
Hope this Helps!!
Hi @AP_9587236 ,
I have not observed any accuracy issues in that widget, at least in ThingWorx 9.3.3
Could you please:
  • Let us know the ThingWorx version you're using
  • describe what you meant by "accuracy in selecting value is low" ? One efficient way to do this is to say: I wanted to achieve this behavior, and instead the following happens. A screen recording could also work if you believe it is easier for us to observe this behavior.
Ashritha15-MoonstoneAnswer
Hope this Helps!!
Between the range 0 and 2000, if i want to select min=200 and max = 600 means, it is difficult to select exact value.
Support
Hi @AP_9587236.
If you're running 9.3, there's also a property called EditableValue which will allow you to enter the value in the box above the slider.
--Sharon
