pshashipreetham
May 27, 2026 6:32 PM UTC
Arbortext Content Delivery toThingworx
I have a use case where I need to get the data from Arbortext Content Delivery and write back to it if needed.
Is there a way to do this? Have any done this before?
slangleyAnswer
Support
Jun 2, 2026 8:43 PM UTC
Hi ​@pshashipreetham
To retrieve and write data to Arbortext Content Delivery, you should be able to utilize the APIs provided by the platform. While specific implementation details may vary based on your use case, the general approach involves:
  1. Data Retrieval: Use the available APIs to fetch content from Arbortext Content Delivery. This typically involves making HTTP requests to the appropriate endpoints that return the desired data in a structured format (like JSON or XML).
  2. Data Writing: If you need to write back to Arbortext, you will again use the APIs, specifically the endpoints designed for data submission or updates. Ensure you have the necessary permissions and follow the required data format for submissions.
For detailed guidance, refer to the official documentation of Arbortext Content Delivery, which should provide specific API endpoints, authentication methods, and examples of requests.
--Sharon
slangleyCommunity ManagerAnswer
Support
--Sharon
pshashipreetham
Jun 4, 2026 11:31 AM UTC
This helps.
Thanks.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
