3-Newcomer
Aug 12, 2026 5:47 PM UTC
Article - CS345914
Does anyone know whether this case was solved and closed?
rics813-NewcomerAuthor
3-Newcomer
Aug 12, 2026 5:48 PM UTC
Aug 13, 2026 8:24 AM UTC
The customer who originally reported this issue disengaged from the investigation before a resolution was reached, and the root cause was never identified.
If you are experiencing the same issue and are willing to investigate further, we recommend opening a support ticket with the FactoryTalk Historian Connector vendor. If the product is still under support, their team can engage with us as needed to continue the investigation and help determine the root cause.
Support
Oct 9, 2026 7:00 PM UTC
Hello ​@rics81,
Hope you are doing well!
I received an article feedback from you regarding this article and I have sent an email at that time with the clarification.
Please let me know if you have any further questions/concerns regarding this article. If the workaround doesn’t help, please let us know. We are happy to open a case on your behalf.
Abhiraj
