Association between two things from different templates
Hi Team,
Need assistance on accomplishing association between things of different templates(that doesnot have inheritance between them) may be primary and foreign key relation or must use a dataTable to achieve this?
Can any one pls suggest
PaiChungAnswer
22-Sapphire I
Thing1 would have a property that helps it to 'maintain' what other Thing(s) it 'relates' to
so I could do something like
Things[me.myRelatedThing].someValue to access a property value in that related Thing.
22-Sapphire I
Often times we use a Network for this.
Not sure if there is an actual hierarchical relationship
else you can use a property in either Thing to 'point' to the other Thing
vijay51-VisitorAuthor
Thanks for the reply
Can you pls brief on
PaiChung22-Sapphire IAnswer
22-Sapphire I
