At runtime showing exception for the dependency jar
Hello Team,
After the import is successfully imported while running the service, exception is thrown for the dependencing jar
But the above dependency jar is shown in thingworx extension monitor.
Using gradle for extension
Any help will be greatly appreciated
The image / file you have attached can't be loaded for me, I assume it's exceeding the maximum file size.
To the topic, I am assuming the dependency is not met even though you have the jar in question in the extension monitor because the version might be a miss match, either your jar is too old or too new.
Without further details I would suggest to test with a newer / older version and see if you're still getting a exception.
Pascal
Support
Hi @vijay5.
If the response provided by @pgrodowski helped to solve your issue, please mark it as the Accepted Solution for the benefit of others with the same problem.
--Sharon
