Automating mashup creation?
I need to create a large number of mashups and was wondering if there is a faster way to do so than navigating the composer and creating them manually. Is there a way to solve this problem programmatically, i.e. automate the creation process when given a list of mashup names?
Thanks in advance!
Any composer action it's an API REST Call, if you replicate it you can do it.
You could also build the Mashup XML via Import Entities (to see Mashup XML format, export a Mashup through Export for Source Control for instance)
