Axeda Embedded OpenSSL Issue
Hello, I would like to make the embedded agent work on my machine but no clue why it doesn't.
I have AgentEmbedded-6.9-12 and I'm having problem with openssl, Which version should I use for this particular version release? I used some random openssl versions from the internet , and each time the error is different and the release is missing the files. What do you suggest please?
Hello @KIWANOVIC ,
Pls checke the following article:
1. For Axeda Agent Openssl Faq: https://www.ptc.com/en/support/article/cs232058
2. To export SSL certs in Axeda Agents: https://www.ptc.com/en/support/article/cs221933
3. Guide link: https://www.ptc.com/support/-/media/support/refdocs/Axeda_Connectivity/6,-d-,9,-d-,4/Using_SSL_with_Axeda_Platform_v6_9_4.pdf?sc_lang=en
If the issue still  persists pls share the error and Axeda Platform version.
Regards
Bhawna
KIWANOVIC4-ParticipantAuthor
Hello, when I downloaded from here it didn't came with openssl, so I had to include one myself, and it depends on the version, when I try to build the demo projects just to start, I have errors of type undeclared identifier, and file not found (from openssl files err.h and ssl.h) and if I try to use another version of openSSL the problem is resolved but now we have issues with the files that came with openSSL and it's a non ending cycle.
