Bar chart truncated XAxis label
I'm working on ThingWorx 9.3.5, I have difficulties on styling the XAxis label for bar chart widget. As you can see on the image, the XAxis label is truncated due to insufficient space at the XAxis. Is there anyway to add new line below instead of truncating it?
PEHOWEAnswer
Hello @MA_9708362,
Did you try setting the "HorizontalAxisMaxHeight" and "HorizontalAxisLabelsRotation".
I do not expect the first will give you the result you are looking to find.  I would expect that the second will give you a better result.
PEHOWE17-PeridotAnswer
Hello @MA_9708362,
11-Garnet
Worked on a similar issue today as well.  "HorizontalAxisMaxHeight" gave the extra room for my vertical text.
Thanks.
