Best approach to have checkbox with name in a tree hierarchy only for the child elements
Hello ,
I have a data source with parent child relation.
Eg:
Fruits
      True,Orange
      False,Apple
Vegetables
      False,Potato
      False,Tomato
I should allow the user to select few fruits and few vegetables. What would be the best approach to achieve it.
I tried with Advanced Tree Grid but i could not get the checkbox to be in the first column from the positioning in the settings.
1. What can i do to get the check box appear in the first column.
2. If there is any better approach with other available widgets.
Thingworx version 9.1.5
Support
Hi @sbt.
You could try using the List widget and turn on multiselect in the properties.  If there's more to the use case that needs to be considered, please provide some additional detail.
--Sharon
sbt15-MoonstoneAuthor
I can use list widget if i have just a general list. But i cannot have drill down of parent and child in that where just child can be selected.
Below image just for info.
Thank you!
I'm not aware that you can prevent the user to select some entries and some not. Do you really need a checkbox?
Normaly we just use the "selected style" to mark that the user selected an entry:
For sure he can also select "Fruit" but this we have to filter in our service.
