Best practices on defining INFOTABLE field in STREAM or DATATABLE
Hi All,
Is there any best practices to define a data shape field as INFOTABLE and which is attached to datatable or stream?
What about data consistency and performance of the system?
Any limitation on INFOTABLE field datasets?
Thanks & Regards,
Sathishkumar C.
rosharmaAnswer
@Sathishkumar_C : Hi Sathish,
you can refer below article on Best practices on Using the Infotables and how memory intensive they can be
https://www.ptc.com/en/support/article?n=CS266583
additionally i have attached one PDF document on how can we work with infotables.
Hope that will help
22-Sapphire I
Are you experiencing any particular issues in doing this?
There aren't any specific best practices for infotables in infotables. There are some articles on DataTables and Streams and their limitations that probably is the best I can point to.
Thanks for the response @PaiChung.
In INFOTABLE field dataset how many rows of data can be stored in both DATATABLE and STREAM?
I am going to update frequently at INFOTABLE field dataset. I am facing performance issue? While query and update actions it lagging little bit. Is there any best practices for these kind of scenario.
rosharma16-PearlAnswer
Hope that will help
