22-Sapphire I
We recommend all time stamps are in UTC
If certain devices/systems use local or server time and can't convert that to UTC then you will need to maintain information about the timezones these systems are in so you can properly shift their timestamps.
Thingworx itself records all timestamps in UTC
Thanks for the response.
I am taking the same example.
Server - UTC
User - UTC+05:30
Machine (Kepware) - UTC+08:30
If i want to log the data with Value Stream, How i have to proceed? In this case, anyway value stream data timestamp will be in UTC+08:30 and Server time in UTC. How user will view the data?
Support
Hi @SathishkumarC.
Are you pushing your own timestamps to the platform with timezone information, or are you allowing the platform to generate the timestamps?  This community post might be helpful since you're using Kepware.
The user's browser should display the time correctly for their timezone.
--Sharon
