Aug 22, 2017 3:09 PM UTC
Best way to work with Analytics?
I clicked through the step by step tutorials of thingworx analytics (builder/rest stuff). The main problem on this tutorials, you work only with csv/json-files not with realtime data which come from a thingworx thing.
How can I put a real time data stream into analytics to predict an upcoming error? How can I get a list of upcoming maintenance (e.g. abc-thing goes wrong in round about 3days)? Why I need an externe java program for anomaly detection (this should be a part of analytics O.o)?
What is the best (practices) way to let thingworx work with analytics?
Aug 22, 2017 7:52 PM UTC
David,
Thank you for posting to the ThingWorx Community.
Firstly, what version of ThingWorx Analytics and Builder are you using? Are you deploying in a Windows or Linux environment?
Have you reviewed this article, which has information how to setup Anomaly Detection for streaming data using Kepware?
Neel
drichter1-VisitorAuthor
Aug 23, 2017 11:00 AM UTC
I'm working with Thingworx 8 and Analytics 8. Both instances are running via Docker on an AWS instance (Linux). I don't have ssh access to this (only via browser).
Do I really need kepware? Do I need it for real time data analytics or only for anomaly detection?
Aug 23, 2017 4:09 PM UTC
David,
Kepware is just one tool that can be used for the real-time data streaming, and as you can see most of our documentation and training materials utilizes Kepware as an example. As the user, you can decide if you have another service/tool to provide and stream the data to Anomaly Detection.
Neel
Aug 24, 2017 4:07 PM UTC
David - there is an "Anomaly Detection How-To Guide" that may help with some of your questions.  It uses a java-based data simulator to mimic data being sent from an iot device/gateway.  It also covers how to setup your environment to implement anomaly detection.
