Mar 4, 2016 12:58 PM UTC
Bind data to tree
i have a data table which i need to bind tree. its just a simple data table. i tried to bind with tree by setting parent and child field. but still i am not able to see any data.
is there any way to bind with tree.
thanks.
Sandeep
Mar 4, 2016 3:01 PM UTC
You can provide a datatable as input for the tree, but the datatable must have the following columns:
fromtoconnectionType
spandey11-VisitorAuthor
Mar 7, 2016 2:36 PM UTC
Thank you Sebastian,
i have added above columns, but i don't want to use connections like-
connections = Networks['NetwrokName"'].GetNetworkConnectionsWithTemplate();
i have a simple data table where i have added three columns- "from","to", "connectionType".
after querying i am getting data. but while binding with tree, i don't see any data in tree.
Note : i have tried with network connections, then tree is populated, but i don't want to bind network data, simply i want to display some data in tree view. so is there anyway where i can achieve binding tree view without getting network connection.
My tree has nothing to do with network connection, it simply need to bind data based on parent value like -
ClassroomA
          -A
          -B
          -C
ClassroomB
          -D
          -E
          -F
Sandeep
