Bind HTML in Container
I have one service that return the html code, this html code generated based on condition of device properties. I want to display that HTML in Container, so how can I achieve this
jenscAnswer
It sounds like what you want is to use the HTML TextArea widget.
It lets you show HTML in a container.
Jens
jensc17-PeridotAnswer
Jens
there are several ways to display HTML elements.
If the data ends up in a grid, you can set the Column Renderer to "HTML" and Format to "with Formatting".
An alternative is the value display. (Help Center)
Here you can also set Renderer "HTML" and Format "with Formatting".
Best regards
Marc
