Binding services from datatable
Hi all,
Is there any disadvantage if we bind the services from datatable directly on mashups?
Thank you!!
I don't think there is a disadvantage, but it's good to have a wrapper, especially for the services used in data transactions from DB. Moreover, if you have a wrapper service, then you can also handle inputs and outputs according to your need and use case.
Mukul
Mukul
Thank you @Mukul_467346 for your response!
