Blank Google map
The google map sometimes doesn't show map, only labels like "Google", "Term of Use" are seen.
How to fix this problem?
Mak
    Sometimes the map widget can get whacked if data is not properly bound to it. Check your bindings, check your actual data being bound, and that usually resolves issues for me.
