Blinking LED Display Widget
I have got a LED Display Widget.
When the value is less than 5, I change the color to red.  How can I make the number blink?
Dan
Hi Dan, do you just want to change the color at once the moment the value goes below 5 or you want it to continue blinking the moment values goes below 5. If it's just about changing once you can do that with State Definition
dmahoney1-VisitorAuthor
Thanks.
Yep, state definition got me to red digits. Now I would like to add blinking and didn't see any builtin way to do it.
Dan
Hi Dan Mahoney​,
As per my knowledge; this feature(number blink in LED widget) is not available out of the Box. You may look into widget modification and custom extensibility  to develop your own solution. Attached is documentation/guides.
Hi, I think about a workaround. You can place a second empty LED Display widget (2) on the first one (1). When the value of (1) is less than 5, use a Validator to activate an AutoRefresh which changes frequently the Visibility of (2) on (1) (with a service, a Validator widget, a Expression widget...), to make a blink effect.
Hello qngo,
I am having the same requirement of blinking LED, and I am trying to implement your solution (workaround), but I am not able to understand it completely. Being a newbie to thingworx platform, I would request you if you can explain your workaround in a little detail in steps.
