Breadcrumb widget
Hi, which widget i need to use to achieve my requirement in thingworx 9.1. Attached a screenshot for your reference.
Hi @bhavya,
If you want to construct the 4 steps' links shown as the attached image and the links are executed when clicking on those, you can consider the Breadcrumb widget with Custom CSS on it.
More detail about breadcrumb and custom CSS you can refer to Breadcrumb Widget and Custom CSS.
/Yoyo
I don't know the exact widget but for work around you can use multiple sliders attached horizontally to each other.
Regards
Shyam
