Feb 5, 2022 7:29 PM UTC
BUG REPORT: getting a json element whose key contains only digits
DESCRIPTION:
Thingworx service does not complete if getting a json element whose key contains only digits.
STEPS TO REPRODUCE:
1. Define `test` as a JSON property of a thing
2. Run the following service
me.test = {"123": "456"}
me.test["123"]
// Java class "org.json.JSONObject" has no public instance field or method named "123"
JSON.parse(JSON.stringify(me.test))["123"]
// Works (workaround)
ERROR MESSAGE:
VERSION
 9.1.5-b698
I'm submitting the bug report here since there is a paywall on the contact us support page and this might be a big issue since it is interpretting the text of the key of the json object as code (or at least as a literal).
slangleyAnswer
Support
Jun 7, 2023 1:46 PM UTC
Hi @BP_9999767.
A fix for this issue was delivered in ThingWorx 9.4 which is now available for download.
--Sharon
Feb 7, 2022 8:33 AM UTC
The error you are experiencing was also discussed in the following thread - "How to convert infoTable to json?": https://community.ptc.com/t5/ThingWorx-Developers/How-to-convert-infoTable-to-json/td-p/520804
Support
Feb 10, 2022 3:45 PM UTC
Hi @BP_9999767.
We tested and were able to recreate the issue.  We also found that we have an open bug report on this.  I am following up for a status and will post it here once I receive more information.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @BP_9999767.
--Sharon
Apr 15, 2025 11:42 AM UTC
The issue persists when writing single tags. Assuming the same scenario as in the original post with the test properts, this most simple code will fail with the same error (has no public instance field or method named "123"):
// Fails
me.test["123"] = "456";
// Works
me.test["a123"] = "456";
Tested in Version 9.5.6-b1150
Apr 22, 2025 6:59 AM UTC
@BennyB
per the solution of below article,  we can use JSON.parse method to modify JSON variable.
https://www.ptc.com/en/support/article/CS404027
Below code worked on my local TW8.5.3. Can you double check please?
var t = JSON.parse(JSON.stringify(me.test));
t["111"]="223";
me.test = t;
