[Bugreport] Title bug in nested Fieldset
I found a bug in the Fieldset-Widget. Nested fieldset inherit title of the parent fieldset.
Scenario:
I put three fieldsets inside of a other fieldset. The parent fieldset gets his title from a service. The first child fieldset gets its title from a other service. The second has a static string as title and the last child fieldset has a translated title (via [[translationToken]]).
All fieldset now gets the same title (on runtime) from the parent fieldset. This bugs only occurs if the parent fieldset get the title via binding.
Tested TWX versions:
- ThingWorx 8.5.2-b90
- Thingworx 9.0.0-b9557
slangleyAnswer
Support
Hi @drichter.
This issue is being addressed in ThingWorx 9.1 targeted for release at the end of 2020.
--Sharon
 @drichter
Thank you for reporting this.
I have done a quick test and I can indeed reproduce.
I will report this to R&D and will post the reference here once done.
Thank you
Christophe
For the record, this has been reported to R&D and is now documented at https://www.ptc.com/en/support/article/CS327150
Support
Hi @drichter.
The reported issue has been targeted for fix in the next 9.x release.  Once we have further details regarding that release, I will post them here.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @drichter.
--Sharon
