Build C SDK issue - error LNK1104: cannot open file 'twCSdk.lib'
I am following https://developer.thingworx.com/resources/guides/thingworx-c-sdk-setup-guide/connection-test-setup
I initially faced a lot of errors in finding various paths, but after including the paths in VS 2013, I am stuck at
I found that there is no 'twCSdk.lib' file in the downloaded file. Is there any link for me to download it?
Could you attach the log of a full clean build? This error may be the result of an earlier build failure.
