Dec 15, 2019 6:14 AM UTC
Building Predictive Analytics Model from Value Stream
How to use and pass Value Stream data of Thing to ThingWorx Analytics Builder for building a predictive Analytics model.
Aditya
cmorfinAnswer
Dec 16, 2019 11:12 AM UTC
Hi @adityak506
Here are some options:
1) Using the CSVParser extension you can export the Stream Value data to a csv file. Then you can use this csv file to create a dataset inside ThingWorx Analytics Builder.
2) You can also do this in a automatic way:
  1. use QueryNumberPropertyHistory() service to retrieve the Value stream data
  2. loop through all the desired records to build an infotable that will represent the dataset data
  3. create a info table using the AnalyticsDatasetRef datashape to build the dataset infotable.
  4. pass this dataset infotable to the AnalyticsServer_DataThing.CreateDatasetWithDatasetRef().
    Note if you want to see the dataset in Builder, add the tags builderdataset and builderdatasetname:<your dataset name>
Hope this helps
Christophe
cmorfin19-TanzaniteAnswer
Hi @adityak506
Hope this helps
Christophe
Jan 7, 2020 10:41 AM UTC
Thanks Christophe
