Button selected style
On click of a button I am getting border on all sides of a button.I want to get only border in the bottom.I tried using css but it doesn't work.
My css code :
#root_button-7 .button-element:active
border-style : solid;
border-width : 2px;
border-bottom-color : #77c5f9;
border-top : none;
border-right : none;
border-left : none;
Please find the attached file.
raluca_edu
Try to use !important, usually this works to overwrite the existing css:
border-style : solid !important;
border-width : 2px !important;
border-bottom-color : #77c5f9 !important;
border-top : none !important;
border-right : none !important;
border-left : none !important;
Hope it helps,
Raluca Edu
Support
Hi @krishnakomal123.
I assume the screenshot you provided depicts the results you're currently seeing.  Can you provide a mock up of what you expect to see?  Are you trying to show that the button has been clicked?
--Sharon
It is done in photoshop.I need to do it in thingworx using css which I am unable to get.
On button click ,only the bottom border of button should have line as shown in the image.
I want style to exist after button click also.i.e focus style as attached pic.But it's not impacting.I have tried below code.It doesn't work.
#root_button-7 .button-element:active .button-element:focus
