C sdk agent is not able to send data to server
We have a C-SDK based application and it was sending data to the thingworx platform. I have cloned the application into new instance and tried connecting the agent, but agent is not connecting and throwing below error:
2020-09-05 18:59:25,908 TW_SDK--ERROR TW_VALIDATE_CERT: Certificate rejected.  Code: 10, Reason = certificate has expired
I'm using the ThingWorx SDK version: 2.1.2
Can someone please provide inputs to overcome this issue.
-thanks,
Abhiram
Your certificate validation is getting failed, you can check this : https://www.ptc.com/en/support/article/CS329206
