C# SDK XML BaseType Mapping
Hello
I am struggling   to find how to map a XML parameter  of a service to a C# type.
Currently I have that:
public static void PutWorkOrder(
[ThingworxServiceParameter(name = "WorkOrder", description = "XML document", baseType = "XML")]
XmlDocument WorksOrder)
But I am not sure that  XmlDocument is the right type for mapping . ( Always null when debugging)
Thanks a lot
Hi
I found the problem. It was a typo in the parameters 😉
Support
Hi @SD_9534978.
This looks like a small portion of the code.  Is there somewhere else in the code where you loading in the XML document?
--Sharon
SD_95349781-VisitorAuthorAnswer
Hi
Support
Hi @SD_9534978.
Glad you figured it out!  Please mark your last response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
