Call a common entity service, independently from entity type
I have an infotable with type EntityReference (just name and type field), it contains different objects like mashup, menus ,things, etc
for each entity I need to call its related common service (on my case SetProjectName) :
for things
   Things[entityname].SetProjectName("myproj")
for mashups
   Mashups[entityname].SetProjectName("myproj")
for users
   Users[entityname].SetProjectName("myproj")
.... and so on for almost all types
is there a way to call SetProjectName intependently from entity type ?
nmillesonAnswer
@iguerra ,
You could try this.. it works for me in 9.0
var entitiesHash = {"Things":Things, "ThingTemplates":ThingTemplates}; // and so on...etc..
var a = entitiesHash[EntityType];
var b = a[EntityName];
var result = b.setProjectName();
EntityType and EntityName are inputs to your service..
Hello @iguerra,
The easiest way to accomplish this is by checking the entityType and creating a conditional statement for each type. Find an example below:
if (entityType == "ThingTemplate") {
 ThingTemplates[entityName].SetProjectName({
		projectName: undefined /* PROJECTNAME */
} else if (entityType == "Thing") {
 Things[entityName].SetProjectName({
I hope you find this helpful.
Emmanuel
iguerra16-PearlAuthor
Hello @emscur
yes this is what I already coded, there are about 18 entity types (I used switch-case)
It's very long service with almost the same code repeated on each case section
I was thinking if there where a easier way or a method to call an entity differently, something like
AllEntities[entityName].myCommonService()
but seems not ....
Hello @iguerra,
Yes, that is the only way to achieve this for now. However, I would recommend posting your suggestion to the ThingWorx Ideas forum for consideration. We appreciate your feedback!
Emmanuel
Support
Hi @iguerra.
If you're happy with the solution provided, please mark the appropriate post as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
