Can I call a Thing service from the Custom CSS of a Mashup?
Is it possible to call a Thing service from the Custom CSS of a mashup?  If so, how?
Example:
.label .widget-ptcslabel::part(label) {
     display: Things["Thing"].service({
                   ProcessOrderNo: ProcessOrderNo /* STRING */});
jenscAnswer
Better late then never.
From what I know this is not possible no.
If you want to do something based on a service, you would have to use mashup functions like an expression or use a service to return a string with which custom CSS class to use.
Something like:
if (useClass1) {
 output = 'class1';
} else if (useClass2) {
 output = 'class2';
And then just bind this output to your customClass property on the widget you want to target.
It is a little cumbersome I agree, but as we can't use jQuery or similar in functions, this is the only way I know how.
Jens
jensc17-PeridotAnswer
Something like:
if (useClass1) {
 output = 'class1';
 output = 'class2';
Jens
